Replacing Stringers and Deck.
Spork Schivago
I know this has been asked many times. I have been searching the Internet and these forums for a couple days now and still have questions. Sorry if this has been answered already. We are replacing the floor and the stringers in our supposedly 1972 Penn Yan. We removed one of the floor boards (it was around 4 foot by maybe 5 foot by maybe a half inch). It was really rotten. The stringers where like a check board which I wasn't really expecting...They're rotten as well. For the stringers, what type of wood are we supposed to use? Any pressure treated wood? The ones that run from the engine to the front of the boat we think are 2 x 2's. The ones that run from side to side we think are 2x4's. Also, I've read some where that people say we are supposed to epoxy the boards first? Does that mean use epoxy resin or are we supposed to use fiberglass resin? Is there a special type? And after that, what is the next step? Do we have to fiberglass them? And is there a minimum thickness to the fiberglass? Right now, they have a thicker fiberglass on the stringers than what was used on the floor boards. We was thinking for the floor, we'd just use plywood and treat it with something. Would we use some sort of fiberglass or Epoxy resin? Would we use epoxy? Do we have to fiberglass the deck boards once we finish installing them? And if we use pressure treated wood for the stringers / deck, do we have to dry it out and if so, for how long usually? Sorry for all the newbie questions. We got a bit confused reading all the posts.
Spork
NoKlu
Re: Replacing Stringers and Deck.
The best thing for you would be to read a few of the threads in the completed projects forum. They will take you from the beginning to the end of the project. The hull extension with pics thread is a good resource to check out. It's long but very detailed and covers everything from materials to the kind of safety equipment you will need.
Spork Schivago
Boss,
Thanks for the reply, best thing we've come across since we started looking. I think that'll do just right. It definitely is long. The index helps a lot though. I'm glad it goes over the whole boat repair because it looks like we have to replace our transom as well. Thanks again for the response!
Peace
Bob_VT
Plywood either exterior or marine grade either will work fine for stringers and decking. Regardless of what you use it will have to be sealed up with resin and CSM......... same for the transom.
There is very very little dimensional lumber used in the restores.
Got some copious free time :) read through this thread http://forums.iboats.com/showthread.php?t=234392 for a wealth of building knowledge!
Welcome to iboats!
