Matthew A.
- Joined
- Jan 24, 2006
- 232
88' 85 hp Force. Seperate power trim/tilt ram w/single shock...2 wire motor.
Seloc recommends replacing the oil for the trim/tilt unit since they advise against mixing oil from one manufacture with that of another. They even explain the steps on how to check and/or add oil when neccessary as well as how to bleed the system of air.
However, Seloc does not list the procedure for draining the oil out of the system should it be desired or neccessary to do so. Is there a specific procedure for bleeding the pump and trim and tilt cylinders and lines of oil?
