I have a 1989 90hp 3 cyl, 2 stroke Mariner outboard.
I am replacing the tubing between the oil pump and fuel pump. I was thinking of attaching the new tube to the oil pump and then fill it as well as possible with oil, and then attach the other end to the fuel pump? Would this be sufficient? I have attached a pic of the area. There is a little tubing still attached to the oil pump, and you can see where it should connect to the fuel pump.
Any advice, ideas are welcome.
Thanks
K
Thanks
K
