Hello. I have an older aq131a with the 275 out drive and it is making some rattling noises from the drive shaft area when its running. My question is... can you remove the drive shaft from the boat by taking the top part of the transmission off and sliding the shaft and the part of the transmission out? or does the motor and out drive need to be separated? Also can that bearing be replaced that you can see where the drive shaft goes thru it at the same time. Thanks.
