Re: Replacing wood flooring in jon boat
My suggestion would be to use marine-grade plywood, then completely epoxy-encapsulate the wood. That means the top, bottom, and all edges... ESPECIALLY the edges! This is where the water will really wick into the grain and cause delamination if it's not sealed.<br /><br />You can use epoxies from West, System Three, Raka, epoxyproducts.com, or others. The best price that I've found, is about $33/gallon + shipping - but this is considered to be a long-term protection. The point, though, is to seal the wood. Epoxy does break-down with UV rays, though, so it'll need to be painted or coated with a UV inhibitor/protectant.<br /><br />G'Luck!<br />Rex S.
