reply to r.johnson &dphmarine (piston blown)
blitzman17
had compression test done at my slip by tech that was his diagnosis didn"t have cylinder pulled to inspect what are your recommendations is this possible to have compression test performed at slip or does it have to be done at shop please reply thank you for you guys response
DHPMARINE
Re: reply to r.johnson &dphmarine (piston blown)
benthooks,<br />Sounds to me like you have problems that will need having the boat at the repair shop.<br /><br />The compression can be tested in the water,and the cylinder head can be pulled there as well.But beyond that it needs to be at the dealer for anything else.You'll probably save a bit by having everything done on shore.<br /><br />DHP
Solittle
Why not do the compression check yourself? And why do you want to check it??
