I have a 25' suntracker tri-toon, it has an older mercury 150 black max on it now with a 15" x 19 pitch 3 blade alum prop, WOT is 5300 rpm, I am repowering with a 2002 Suzuki df 140 four stroke, will the same size prop work or should I start with a 17 pitch to try and bump the rpm to around 55 5600 rpm? assuming the power is close to the same between to two motors I am thinking this should be a starting spot. Anybody done somthing close to this with any suggestions. I am kind of shooting in the dark.
