Repower 86 Starcraft Mariner 180
Status
Not open for further replies.
bawc05
Need to repower my Mariner and was wondering if anyone had any suggestions or knew the best size motor for this boat. Does it require a 20" shaft or will a 25" work? Thanks
jbcurt00
Depending on what your Mariner measures, determines the length of motor you can drop on w no modifications.
The # of unsatisfactory results posted is much higher then the # of successful modifications to accomodate an 'incorrect' length motor
GA_Boater
According to the 1986 brochure the MR180 takes a long shaft up to 120HP.
roscoe
You are gonna run into performance issues with a 25" motor.
You need a 20".
Or a $300 jack plate and a 25".
I'm running a 115 hp, but you could easily use a 90 hp with the right prop.
fishin98
You need a 20".
+1...are you going to repower new or used, 2str or 4str, what brand?
bawc05
2 stroke more than likely--not sure what brand as I'm keeping options open for best deal. I know I would like to stay between 90-115 hp
Status
