Re: Repower options....4.3
When I first got my boat I started thinking the same thing, because it?s also 4.3 powered. Throw a small block in it and go faster. Well, I talked with the machinist at my work about it and he said the same thing as everybody else. He asked me how much time and money I wanted to invest in chasin down parts or fabricating things to make it work. Not to mention it will be heavier.
He tells me the 4.3 is basically a small block less 2 cylinders. So, keep it simple and if I wanted to make more power just put some go fast goodies on the 4.3 and tune it to run great. So, following his advice, I am collecting parts as I go, and I am still using the boat while I am building the new engine.
This is what I am building.
I am using a 1988 4.3 engine block (mechanical fuel pump block)
Balanced rotating assembly, flat top pistons
1998 4.3 Vortec heads with 2.02 intakes and 1.60 exh valves
Ported heads to clean up the flow and springs to match the camshaft
Comp Cams XM256H or XM262H (have not decided yet) marine cam specs
Edelbrock 2114 intake manifold and a 4 Bbl carb of some flavor (yes, marine type)
Not really anything special about it, the parts are readily available, I got my Vortec heads off of craigslist, but you can find most of them on ebay. Best of all, for the most part, everything fits back in the same place. I think I will have to deal with carb linkage but it shouldn?t be that big of a deal compared to swapping in a complete V8 engine and fabrication many things.
Not sure what the hp figures will be, but it should be more than what it is now, and based on the heads, intake, and cam specs, it will flow to 5500 rpm, but I will keep it under 5000 rpm.
Hope this helps.
