Hi,<br />I do not know if Evinrude E-tech larger outboards has been released yet but they have a 200 hp E-tech that weights 516 lbs (234 kg). Also available in "Saltwater edition". To heavy?<br />Unproved and such that will be slightly negative. But You maybe should check that alternative so You do not miss an outboard that perhaps will suit Your needs (hp/weight/price?/etc).<br /><br />It is also the E-tech 200 H.O. that is even more powerful (and a few lbs lighter).<br /><br />Yamaha has also the 175 2.6L V MAX HPDI that might be of interest, 468 lbs (213 kg). Or Yamaha 200 3.1L V MAX OX66, 509 lbs (231 kg).<br /><br /><br />/Bo
