greg82255
- Joined
- Oct 26, 2009
- 781
Hello,
I currently have a 1986 Formula 206 Spyder with a Merc 260/Alpha One. It does about 50 on a good day, but I'd really like to get some more speed out of it (60??). The engine has 800 hours, and I don't want to invest a lot of $ into an old motor, so I am thinking of buying a long block at the end of this year and taking the good parts from my old motor (obviously only the ones that will bolt up), and replacing necessary parts. I've heard good things about long blocks from Rapido Marine, Jasper, and Michigan Motorz. Any thoughts on which one is best, or if there is another out there that is better?
I also really don't want to replace the Alpha drive if I don't have to (more $$$). I've heard they're rated for up to 300 HP, but I've also seen people running 454s with them. How much power can I really put into an Alpha drive, and what will happen to it if I run it over its specified limit? I've remanufactured 350's with 315 hp at the crank(probably vortec?). Would that be ok? Also seen 383 strokers with 350-400.. that would be ideal, but not if I'm going to ruin the drive. Any thoughts/concerns please post. Thanks in advance
![mercury-quicksilver-power-2-variable-pitch-prop-48-823510a25-25p_4596042[1].jpg mercury-quicksilver-power-2-variable-pitch-prop-48-823510a25-25p_4596042[1].jpg](https://forums.iboats.com/data/attachments/86/86120-2adecbf20dc082e5be8fc2376af9b9f9.jpg)
