Repower
deputyb
I have a 1989 Sportcraft 270 Caprice. I have to replace the stringers and put new gaskets on my 7.4 l. Will I gain fuel economy by replacing the 454 with a 350? The boat is a straight inboard. I have the skills in the parts, just need to know if anyone has done this and can tell me if the fuel economy change is worth it. Thank you in advance
No
It takes power to move a boat, so replacing to a smaller motor requires the motor to work harder. In most cases it uses more fuel
dingbat
It takes X HP to move your boat at a given speed. That doesn’t change no matter what power plant you use.
Either does the fact that 1 HP = 2,545 BTU/hr.
Unless the 454 is more efficient at converting BTU to HP than the 350 which is doubtful, the conversion buys you nothing in fuel economy.
deputyb
Thanks guys. I suspected as much, but since the big block is coming out I wanted other opinions.
