request for photo of water inlet hose position
natwales
Is anyone is able to post a photo of an installed alpha 1 (gen 1 if there's a difference) water inlet hose that goes from the gimbal housing to the transom? I've been struggling with a kinked hose and think I've finally got the length right, but I'm still fearing that it may still be bent just enough to restrict water flow at high rpm. I'm not sure what should be considered normal and would feel much better if I had somthing to compare my installation against.
thank you
Bt Doctur
Re: request for photo of water inlet hose position
14 1/4 long, pn 32-41725 33
do yourself a favor and obtain the correct hose .Saves money and time in the long run.
natwales
thanks, thats the hose I used, but still have a bit of a bend with the hose just slightly pinched. Worry that with a little time and vac pressure it could cause problems.
Fishermark
It can be difficult to install that's for sure. The good news is you do not have to worry about vacuum - it is under pressure, not vacuum.
