SierraMark
- Joined
- Feb 27, 2012
- 135
Hello all,
I have been reading these forums and am in awe of some of the great work that I have seen. I hope when I do my restoration it comes out half as good as some of these that I have seen here.
As you can see in my profile and signature I have a 16' 1991 Starcraft Fishmaster that I bought early this spring. I knew when I bought it that I would be doing at least a re-decking and changing out the carpeting on the sides and tops of the gunwales. I will be hopefully doing this over the winter or maybe late fall after the boating season. Right now I am gathering information and making my plan.
I have decided on using Nautolex on the deck and quite possibly everywhere. If I used it everywhere I would probably use 2 different colors, one on the deck and another elsewhere.
I know that my deck will probably 4 seperate pieces of plywood (not getting into the type of wood or the epoxy debate here) meaning that I will have 3 seams.
I have seen 2 different ways to install the Nautolex:
Option 1 is to install the Nautolex on each piece of deck. This allows for the Nautolex to be wrapped around the edges and stapled on the back. This also means that the seams would be visible seems when the decking is put down in the boat. Another thing that it means is that whatever I use to fasten the deck to the hull (SS Screws or Rivets) would also be visible.
Option 2 would be to put down the decking and secure it and then cut one large piece of Nautolex and glue it down. This means no visible seams and no visible screws or rivets.
So what I am looking for here is some input and opinions. Which would you do? Which would you rather?
I actually like the look of the exposed screws (ala Jigngrubs resore) or the clear look with no visible fasteners. One thing, I cant see any seams in Jigngrubs deck, is that because it's a Bass boat and the seam is under the raised front deck?
Thanks in advance for your ideas.
-Mark
-Mark
