Reroute telltale hose
nozipcode
I have just built a box over my 50 hp johnson ( 3 sides, for noise reduction, pontoon boat )
and can not see my telltale in action . I would like to change this . Can I just extend the hose and route it where ever I want......or is this a bad idea ? :facepalm:
Daviet
Re: Reroute telltale hose
You can reroute the hose to squirt anywhere you want, passenges might get upset if you start playing games with a big squirt gun.
nozipcode
Thanks Daviet.....can i squirt it out the top of my box makin' a miniature rooster tails like one of them yammyhaw waverunners ??......or will it just dribble ?
Daviet
The tell-tale is the first thing the water pump supplies water to, if your pump is in good shape it shoot water stright up with no problem. Just remember that on a windy day you may get yourself wet, angle it up and a little to the rear.
nozipcode
Thank you very much. I've learned a lot on this forum......couldn't find a thread on this one . Thanks again Daviet
Daviet
You're welcome, come on back if you have any more questions.
Silvertip
Or you could just install a water pressure gauge.
nozipcode
hmmmmm, I will ponder on that.....sounds like a good idea . Thank you
