rescued a boater in distress today
slag
We put in for the 3rd time ever today on Clinton Lake in Lawrence. We started cruising out to the middle of the lake and saw up ahead of us a lady waving her arms. We made a detour over to the boat in question, a 24 foot pontoon, and saw that their transom had rotted through and their outboard was hanging precariously in the water by the steering cable and controls.
They tossed us us a line and I boarded their vessel and helped the guy hold the engine up out of the water to take the stress off the cables. We eventually tied it off well enough to pull it in with our boat. After we got to the dock, I waited around to help secure the motor better and then wished them well while they loaded up and headed home to fix the problem.
I've pulled boaters in before on jetskis but that was for dead batteries and other simple stuff, but this was new to see the engine hanging in the water with part of the rotten transom still attached.
tx1961whaler
Re: rescued a boater in distress today
Maybe we'll see them post here soon..."my motor went under today, what do I do?"
Good job helping them out.
Fireman431
Way to step up and help. I hope the favor never has to be returned to you.
a70eliminator
Good thing it was a toon eh, sounds like you had some fun.
ralphl
a pontoon with a wood transom??? How old a boat was that? I have never seen a toon with anything but metal..
seabob4
Well done, Slag!!!
H20Rat
my pontoon is a '91, wood transom. Every pontoon i've owned has had a fairly sturdy board for the actual attachment point. It keeps some of the noise and vibration from transmitting directly to the rest of the frame. (the actual transom frame is metal, there is just a single piece of wood that is maybe 16x16 or so, which is bolted to the edges of the metal transom supports.)
slag
it was an 88 (I happened to look at the hull ID when I was standing back there, holding onto the aluminum railing with the other hand holding on to the outboard.
It was plywood sandwiched between two metal brackets that bolted to the boat.
Jeep Man
My older toon was an `88. It had an all metal transom.
Way To Go Slag:D:D:D
They where sure lucky to have you around as hot as it's been out here.
Most people are in the house where the A.C. is at. It,s also great that you
stayed around to help do the loading:)
Now,,,About that football team your town has in there???:rolleyes: L.O.L.
Jim
Borchik
good story...i should print it and give it to my customers when they complain that we wont fix their motors when the transoms are so rotted they are about to fall apart.
Home Cookin'
I tried to tow a toon once--not easy if you don't take the time to set it up right.
slag
I should add that my wife is the one who towed us in. I stayed on the pontoon to help if the rope gave way or if the motor started to drop further or any one of a multitude of things that could happen. She swung wide near the docks and we coasted in.
Last year I had an 87 bayliner that always seemed to need something and I was towed in by a pontoon boat, so it all evens out in the end.
It bears asking: what is the best way to tow a pontoon? I've towed other boats from the bow eye. What is the special trick?
Home Cookin'
you have to be centered: a harness on the tow boat and center line on the towed boat. Once they veer over it's all over.
I suppose the next best thing is to tie alongsides. Steering will still be difficult.
