My gear case is leaking and the oil is contaminated with water so I have torn it all down.
I noticed the Sierra kit only contains a single drive shaft seal.
I am not sure which direction to put it.
It seems like it would need to go flat metal side down to contain the drive shaft bushing.
It also seems like the original seal was larger or maybe there were 2.
I believe I asked somewhere and was told that the modern seals are superior to the older ones.
The main thing though, which direction for the seal please.
Thank you.
Thank you.
