D
DJ
Guest
Re: Reset Switch-OMC Cobra 2.3?
Once a bearing is galled, and yours are, they're done.<br /><br />It may work for a while and then it will sieze when you least expect it. Maybe at wide open throttle. If that happens, it may tear up a lot more than the bearings themselves.<br /><br />If you do not trust the mechanic to not swindle you, I would look elsewhere. At least, he will show you the old parts, if you request them. Ask for a guatrentee.<br /><br />Don't try to go the cheap route. Fix this right.
