I got into some rocks and caused some significant damage to my 15"X17P aluminum 3 blade prop. I was only at idle speed, but it created gouges that were approx. 1/4" deep to front edge of the blades in the area with the worst damage.
I have already purchased a replacement prop, but would like to keep this as a backup/spare. I think it is possible that it might possibly work better than new for some purposes if reshaped.
I put it on my belt sander and sanded away all of the damaged area. It looks pretty good, and if touched up with paint/powdercoat it might not even be apparent that it had been damaged. My concern is that I don't have the blades all identical and it may be out of balance.
Any suggestions on a cheap/easy way to get the blades nearly identical?
Thanks, Joel
Thanks, Joel
