I have an AQ125 with Volvo 270 outdrive. The cooling system is the kind with antifreeze in the engine trading heat with fresh water in a heat exchanger. I fixed a bad cooling problem earlier this year and it seems to be running quite well. However, I've noticed that even a day after using the boat, there is still a lot of pressure in the antifreeze reservoir. So much that if I take off the cap it still spews antifreeze fluid, even with the system totally cold. Is this normal? If not, any suggested causes?
