Re: Resistance/non-resistance plugs
Here you go..........<br /><br />1992 YAMAHA 40 40.0 hp 3 Cyl.<br /><br />Spark Plug Part No. Stock No. Plug Gap <br />Standard B7HS-10 # 2129 # .039 <br /><br />---------------------------------------------<br /><br />Standard & Resistor<br />The workhorse, at the heart of smooth-running engines around the world. Available in standard or resistor.<br /><br />OEM Quality <br />Triple-Gasket Sealing Process <br />Consistent Performance <br />Plug of Choice in Millions of Vehicles <br /> <br /><br />Inductive Resistor Spark Plugs<br />Specified as original equipment in a variety of late-model outboard engines, spark plugs with an inductive resistor are utilized when a CDI (capacitive discharge ignition) system is used. The resistor plug is necessary to reduce radio frequency interference (RFI), to prevent interference with the sophisticated electronics onboard modern boats.<br /><br />Most resistor spark plugs use a "monolithic" resistor, generally made of graphite and glass materials, to filter the electrical voltage as it passes through the center electrode. This "filter" reduces RFI to an acceptable level. Although this type of resistor develops from 1000 to 5000 ohms of resistance, there is no significant loss of voltage to affect ignitability at the electrodes in modern automotive ignition systems.<br /><br />However, outboard marine engines utilizing a CDI system have a much lower voltage output, which would be compromised by a standard resistor plug. Therefore, an inductive resistor is used. In this method, a coiled nickel wire is inserted into the center stem, and held in place by a spring.<br /><br />This coil basically acts as an electromagnet, inducing a magnetic field around the center stem, creating a natural "field" resistor, and reduces RFI to acceptable levels. This method creates only 40 ohms of physical resistance, compared to the 1000 to 5000 ohms of resistance in "monolithic" resistor plugs.<br /><br />While NGK Inductive Resistor Spark Plugs cost more than standard resistor plugs, they provide major benefits in late-model marine outboard applications. <br /><br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
