Re: Resistor Wire
I have a 1977 Mercruiser 250 HP (5.7L) and was having problems with burnt points. I checked the wiring and found that I was getting a straight 12V-13.5V at the primary. I should have been getting 7.2v-8.0 I installed a resister and everything is running fine, proper voltage and no more burnt points. Since I intend to do some rewiring I was looking at replaceing the resister with the proper resister wire, but can not find anything in any of the reference I have checked. So, if I can figure out which wire bundle it is in maybe I can get rid of the workaround and install the proper rig,
