Re: Resolution on fishfinders
Well, actually what Boatist said is just slightly off, but not by much. Actually I'm pretty sure he just mis spoke, because I've seen him explain it before and the little thing I'll mention was right on the mark.<br /><br />Yes, divide the depth by the vertical resolution and you get the size of target that a pixel represents, but that doesn't mean that the smallest thing that can be detected and shown will have to be at least that size, not at all. What that means is the smallest size that can be displayed is equal to that mathmatical result. The fish finder can still accept returns from smaller objects, of they are strong engough, its just that it will only light up that single, or double, pixel to show it on the screen.<br /><br />Here, think about it for just a second. How does the fish finder know how big a target is? I'm not talking about how long the mark is shown on the screen, because that's just a matter of advance rate and how long a usable return was being echoed back from the target. No, what I mean to ask you is how does it know how thick a target is? It should occur to you pretty quickly that its the strength of the return and the rate of decay of the echo that do it and once that registers it quickly becomes clear that it is the strength of the return signal, not the actual size of the target that determines if a pixel is to be lit up or not. Of course its all dependent on the sensitivity of the transducer and the hard- and soft-ware in the fish finder display unit to both be able to discern noise from usable signal, particularly faint ones, and then to be able to segregate and amplify the returns to a point where they are suitable for the display unit. <br /><br />By the way, have you ever passed over a Tarpon in the boat and seen its signature on the fish finder screen? They light up the screen even brighter than a Rockfish, but curiously enough the fish always look sort of flat. I believe its because of the large scales that give a sharp return with an almost immediate decay of the echo so it appears there is no fuzziness under the fish.<br /><br />Anyway I just wanted to point that out. Just because your screen resolution restricts you to being able to show a target no smaller that 5 or 6 inches doesn't mean that a smaller target can't be detected and displayed, it can. Its just that it will be displaybed as if it were 6 or 7 inches, when in fact it might only be an inch or two.<br /><br />Thom
