restoration of 1986 galaxy oak or birch plywood
ok went to home depot and lowes well home depot was cheaper on everything i priced .... now for the question i bought some exterior glued cabinet grade plywood which has a tight pattern and very little to any flaws for the transom....today i found they had birch and oak plywood but the stickers doesnt mention exterior glue...is this safe or better to use than the cabinet grade plywood i bought prevously since i dont see any exterior glue on there.....also the salesman didnt know if it had it in it or not....thanks LeRoy
tpenfield
Re: restoration of 1986 galaxy oak or birch plywood
T​he exterior rated glue is what you are after. . . Anything less would not last very long.
thanks tpenfield that is what i thought but wasnt sure if the birch and oak was made with ext. glue or not....
F14CRAZY
Ensign
Cabinet grade birch plywood is definitely not good for a marine environment. I've had a little rain drip through my windshield rot out one of my cabin door bulkheads
jigngrub
You should give MDO plywood a look, much more suitable for marine applications than hardwood plywoods.
Pmccraney
Lowe's used to carry Auraco, but once that went the way the of the "do do," I've hard a hard time finding ply that will work at the big box stores... Find a specialty lumber yard in your area and they will likely carry one or more of the following: MDO, exterior grade AC Fir, underlayment, even marine... (lots of choices)...
Ayuh,... Hardwood plywood has No place in a transom,... Especially Birch,...
Birch starts rottin', as soon as ya even think of water....
wellcraft-classic210
A few details on plywood.
Cabinet grade plywoods and particle boards typically use an interior grade adhsive-(Urea-formaldahide). I can recognize it by the smell when cut or freshly pulled from a stacked pallet.
Exterior grade ply woods and many OSB's use a different adhesive ( not sure what that is ).
If you can find an exterior grade plywood without voids and seal it your most of the way thier. MDO and other Marine plywoods will often use a better grade of wood ( not pine ) like mahogany that is a little more resistant to water absortion .
The experts may have more to add-- but that's my understanding.
THANKS everyone...i am trying to find a place where i can get some marine plywood but no avail....LeRoy
Woodonglass
Go to a lumber yard, NOT Lowe's or Home Depot. As for Floor Underlayment. It has few voids and uses 100% waterproof glue for it's laminations. Usually uses Douglas Fir Wood
