Restoration Question...
HollaGeo
I frequent the restoration(s) progress of some of your boats. It always amazes me the dedication, perfection and time many of you put into your projects. I recently bought a 1970s Checkmate and it seems pretty solid to me. I'm sure if someone were to rip apart the boat, there would be signs of age. As it sits right now, it is presentable. Is it because it's a Checkmate and could just age well??? When I bought the boat it came with a ton of leaves and misc. junk. It wasn't garage kept. Basically, why do some boat needs a "total makeover" and some don't???
QC
Re: Restoration Question...
If the floor (deck) is good, and the transom is sound, then she is sweet. I would guess there are issues underneath somewhere, but it's possible for them to be good for a long long time depending on many factors . . .
TilliamWe
Banned
... Basically, why do some boat needs a "total makeover" and some don't???
Because some boats are properly cared for and other aren't. And some boat manufacturers do some "extra" things that help their boats stand up to time/weather.
45Auto
What "seems pretty solid to you" could qualify as someone else's "needs total rebuild". Have you drilled the floor, stringers, and transom to check for moisture?
What kind of Checkmate did you get?
I recently finished a total rebuild of a '79 Checkmate Eluder (now just sorting out engine issues). Take a look at my restoration (and others) at the Checkmate forum and you can get an idea of what to look for.
http://checkmate-boats.com/forums/showthread.php?t=15673
Yes, Checkmates are built really really well. Unfortunately they're not immune to neglect. One thing Checkmate has always done well is gelcoat, being 31 years old the gelcoat on my boat is still in amazingly good shape. You'll also learn that the hull is cored with end-grain balsa which gives a very strong yet light hull. Some manufacturers who used that method of construction had problems with the balsa getting wet and rotting after several years, but there are precious few instances of core rot in Checkmates (only when some idiot puts a screw through the hull and invites water in).
Since yours was left sitting outside I'd really poke around the flotation boxes in the rear looking for any sign of softness, check for any sign of soft spots in the deck, and moisture in flotation foam.
Also, you need to join the Checkmate forum, there's people on there (including people that work for Checkmate now or have worked at Checkmate in the past) that can answer any specific questions. What I've found is that there's probably more knowledge about generic fiberglass repair, etc. here on iboats, but far more knowledge specefic to Checkmates (as would be expected) on the Checkmate forum.
