Hello,
I've been doing quite abit of reading and have a good idea of where I'm heading with my project but have a couple of quick questions.
Specs; 1980 Renken V900 18.5 foot
1. How do I find out what the hull is made of?
After reading OOPs hull extension thread it seems most boats are made of a poly resin construction. From what I've read, poly and epoxy do not mix well so I want to make sure I get the right stuff.
2. I'm replacing the floor and stringers in my hull but I don't think they are structural (the stringers) really just floor supports, anyways I've read these shouldn't make full contact with the hull as they will make hard points to the hull. But it seems most of the rebuilds here and on other sites make it clear the entire stringer is set in thickened epoxy (PB) to the hull. What's the correct method?
Thanks
Thanks
