RainmanFisherman
- Joined
- May 4, 2014
- 5
Hello; new to the boards but have followed if for some time.
I recently picked up a 1962 Elgin (Sears) Outboard.
6013 / Model no. 574.60131
Serial no. 62601410-3534
1962 McCulloch 12hp/14.1hp(@5000rpm)
It was seized from sitting in the owner's basement for 20+ years.
He said it was running fine when he put it away.
I soaked the pistons in a 50:50 2-cycle/fuel mix overnight and was able to turn the flywheel by hand the next day.
Propeller spins freely in neutral and the flywheel turns the propeller in both directions with ease
I have drained the gear oil and it is shiny black.
My list of rehab includes, but is not limited to...
1. Clean the carb and replace the fuel lines
- Carter Type N; 3198 or 3199 unable to narrow it down any further
2. Replace the gear oil with Penzoil Synthetic
3. Replace the spark plugs with Champion or AC/Delco equivalent
4. Check compression and spark
5. If all goes well, mix some fuel and test it in the big recycle bin
Hoping to get some ideas on what else I may need/want to do to get this motor on the water.
Carb kit, Magnetos, etc
Thank you all for your time.
Great site; wealth of information!
