restore shine to gel coat, Vertglass???
searay4now
Hey. whats up!, I hear in restoring shine to gel coat that is just a bit dull and not chalky, vertglass or other similar products do the job. What is the long term affects on these products? do the flake off after awhile? if so would I have to strip it off and do it again? what are the pros and cons of products like Vertglass gelcoat sealer??
MIKENVAHBEACH
Re: restore shine to gel coat, Vertglass???
I have used Vertglas for three seasons and have learned a thing or two. First thing is the Vertglas kit gives you the hull cleaner, a boat wash, applicator, sealer and the sealer remover all in one box. These are all great when doing it for your first time and the instructions are helpful. Things I have learned, first give the boat a through cleaning, second scrub the hull, I use soft scrub but any of the advertised hull cleaners will work. Remember, the sealer will cover anything that does not get clean or scrubbed off the boat up, this will look even worse than before. Third, I clean the boat of all cleaner residue, I use acetone, just be careful of all painted surfaces and decals as it will damage most. Fourth, I apply the sealer; I use a 10” piece of artificial chamois soaked in sealer to pull the sealer across the hull in thin even coats. I have a buddy help since the sealer will dry very fast. I would apply no less than 8-10 coats, less than that really shows the streaks and does not give you the best results. Important things never clean the hull with harsh cleaners, like purple, orange or green stuff, they will remove the sealer. I use the blue coral car wash, you can get it at any Wal-mart and it’s cheap. When the finish starts to flake off, and it will, try adding additional coats of sealer, this sometimes helps. I use my boat exclusively in salt water all year and it sits on a trailer in my drive, so the finish requires a new coat every year. Hope this helps.<br />-Mike
LubeDude
Ive conducted some experiments with different products and this is my finding! (Your not going to beleive this) But here goes!<br /><br />Follow the above post, but use a clear acrylic floor polish like Future. Ya, thats right, the same stuff you use on the kitchen floor! It works great and I can see no difference in the outcome! A bunch cheaper too! It will last all season too. Remove it with a heavy cleaner like simple green! Stange but true! You can also apply it with a sponge brush, you will have to experiment some.
crazy charlie
S4N,I assume you have a Searay..?? What color and what year???Searay gelcoat usually can be restored with proper products and a polishing wheel.Things like vertiglass and penetrol are when the gelcoat is too far gone or when someone is too lazy and looking for a miracle fix in a bottle.Charlie
Salty Sal
Hey LubeDude- I figured out the acrylic polymer gig years ago- in fact I posted that info on this forum last year. Some work better than others. I bought some from a True Value hardware and wasn't as good as Armstrong Shinekeeper. Wanted to try Penetrol this year <br />on the gunwhales even though they are white.<br />Doesn't matter to me if it yellows a bit.<br />The boat is a 1977 and the gelcoat on the top of the boat is no longer true white. Now the sides are a different story-blue- and in fantastic<br />shape. Looks phenomenal with acrylic polymer. Wound up stripping the top because<br />it still soaked in dirt.
LubeDude
Crazy Charlie: Yep, thats what people are looking for! Granted its a temp fix, but it looks great!
Tom Glandon
rub the boat down with baby oil, will look like new and last about a month.
