Retainer E-Clip
cc67
I need to know what is the size of the E-clip part #203363. I holds the cam roller on the throttle shaft. For a 1958 QD-19.
oldboat1
Remove the follower and roller assembly and take it in with you. Find a clip to fit that way.
The marine clip is a $7 part.
cc67
I would if I had the clip. $7 for a clip is ridiculous. I thought someone might know. Thanks.
Clips are 19 cents when you pick it out of the bin at your local hardware store.----When a shop identifies the part you need.----Orders it.---Part is retrieved from an expensive warehouse and shipped to you it is a $7.00 part.---And I do not believe anyone is making a lot of money on that item.
oldboat1
and the point of taking in the assembly (which you remove) is to find a clip to fit!
Good luck to you.
cc67
Where I live there are no local hardware stores. So it will be another excuse to take a motorcikle ride.
cc67
Got some clips at Ace today. 3/16 seem to be close to original. Snapped it on and couldn't pry it off with a screwdriver so I should be good to go. 17 cents so I stocked up.
