my motor is a 1982 50hp evinrude!! my question is i removed the bearing carrier and replaced seals and bearings already, but on beginning of assembly i noticed that the retaining ring the three bolts that go through carrier thread into, has an extra hole in it between the threaded bolt holes , this must be for oil to pass through to the carrier bearing or to bleed trapped air off when filling lower unit??the carrier is marked with an up arrow, so obviously the extra hole has to be in one of three positions either 12 o clock , 5 o clock, 7 o clock or it doesnt matter?????? seloc doesnt mention anything about this!!!! Can anyone tell me where this hole should be????? thanks
