..well it just seems to be beginning. A while back, I got a lot of very good help on this forum when I did a complete makeover of the electrical and fuel systems on my 1987 evinrude 225. new rectifier, stator coil, power packs, plugs, ignition coils, starter motor, battery cables, gauges and wiring. what a blast! rebuilt all six carbs, new fuel system,and good to go. the motor went from 3800 top rpms and unable to charge the battery to 5500 top speed and good juice throughout my system. voltmeter reads about 14-15 V when running. accordingly, I have enjoyed about ten hours of peak performance run time on the motor. ..until the day before yesterday.<br /><br />I was motoring along with a warm engine, when heard a sort of whizzing noise under the cowling that got louder and then abruptly stopped with a ping. then again. whiz whiz whiz, zing! and once more. I cut the engine. looking under the cowling, there was nothing I could see, but some bits of shiny metal, looked like razor blades, had materialized in the pan. I limped home on the kicker, and started it again today in my back yard with the flusher. she ran great for a while, warmed up nicely, and then the whizzing started again, seemed to be from the vicinity of the flywheel. I peeked, and this time the tiny bit flew past my ear and into the cabin. wups. I cut the engine, pulled the flywheel, and looked at my brand new stator. at first blush, nothing appears to be the matter, but it turns out that the bits were coming off of the metal guard (or whatever it is) that is on the aftmost two of the stator coils. I know that nothing is, or was, touching inside the flywheel after my big fix-it, but the metal on those two coils is peeling up and flying away! what the hell??<br /><br />re-cap of my big fix-it (electrical)<br /><br />new battery cables and wiring throughout<br />new rectifier<br />new stator<br />all new magnets in the flywheel, glued in the proper orientation with the proper goo.<br />new power packs<br />new ignition coils and plugs<br />new starter motor<br /><br />I bought a new solenoid but have not installed it.<br /><br /><br />so, again and again, people have it pointed out to them that their electrical problems with power packs and stators are the result of a bad rectifier. so, I ran the simple rectifier test that I found described elsewhere on iboats. with my ammeter, and I get a big (but transient) current deflection when I test the rectifier leads against ground one way, but when I reverse the leads, the deflection is small, just a blip. my batteries charge, but there is ONE TIME that I cut battery power while the engine was running. I was worried that I may have killed my rectifier with this, but I checked it immediately after and it passed the test as I described above. now the rectifier has two yellow leads that come out of it. one has a grey stripe- does it matter which of the stator leads is connected to which of the rectifier leads? my rpms read fine, and ground is good. <br /><br />I will email pictures to anyone who is interested, but all they will show is the shiny new stator and another picture shows the shiny bits of metal that are somehow jumping off of the (dead centermost part) of the triple layered metal guards on the aftmost two coils. any ideas whats up? the rest of the stator looks fine, but I figure that I am already in for a new one. should I get a new rectifier also?? I will wait to hear this time before doing anything.<br /><br />thanks, seahawk in seattle<br />beachamd@yahoo.com
