Rev Counter
Taz59
How do I check if my rev counter RPM is the same as Engine RPM ?
Cheers
muc
"Retired" Association of Marine Technicians...
Re: Rev Counter
“shop tach” or scan tool
Taz59
Re: Rev Counter
Hi Muc
I have the scan tool but never used it,so the scan tool will actually tell me what the RPM is
Col
Re: Rev Counter
Hi Muc
Col
Ayuh,.... Donno if yer scan tool does rpms or not, but the Idea is to cross-check with another tachometer that's known to be Right,...
Taz59
Re: Rev Counter
and take the reading from the bottom pulley ???
Re: Rev Counter
Ayuh,... Shop tachs read from the coil, just like the boat's tach,...
Yer just cross checkin' it's accuracy,...
Don S
Re: Rev Counter
Yes, the scan tool gives rpm.
Taz59
Re: Rev Counter
With power off should the rev counter be at zero ???
Silvertip
Re: Rev Counter
Soome do & some don't. It makes no difference what it reads with the engine off -- you know the RPM is Zero. You are interested in it's accuracy with the engine running! Check it at 1000, 2000, 3000, 4000 and 4500 -- ON THE WATER OVER 2000 RPM, NOT IN NEUTRAL.
