Rev Limiter
David Grubbs
I have a 1977 15hp johnson, It is bouncing off the rev limiter and full throttle. Ive put it on a heavier boat, changed prop, and changed plugs. The motor idles fine and jumps right up on plain.Any suggestions as what to try next?
jbjennings
Re: Rev Limiter
It will be news to me if a '77 model has a rev limiter. Not saying it doesn't have one, but I certainly didn't know it. If it is jumping out of gear it is probably your clutch dog.
I'm curious to hear about the rev limiter.
JBJ
David Grubbs
Re: Rev Limiter
I was under the impresion it was a rev limiter, but it is definitly busting up at the top end. I think it is a coil but not sure is there a way to check this other than buy new coils?
bktheking
Re: Rev Limiter
What is the part number on the powerpack that is on it?
