Reverse Bearing Carrier Install
Wills03
1976 Merc 1 Drive
Manual says on final installation of bearing carrier apply Perfect Seal liberally to outer diameters which contact gear housing & to retainer threads.
Perfect Seal is hard to find locally but from searching around I gather Aviation Permatex is the same or very close product.
Is this true?
I have used the Permatex for years on many applications but if I had not read the manual I would have reached for a waterproof grease for the carrier install.
The brown brushable sticky Permatex just seems like an odd choice but if it is indeed the same as Perfect Seal that is what I will use.
Thanks for any input,
Wills
Don S
Re: Reverse Bearing Carrier Install
Permatex will work just as well as perfect seal.
