There's times when reverse can be your friend. Like something cropping up you weren't prepared for and need to either stop or actually move backwards. Also, if wind is pushing the boat too fast to dock or load. So while you don't want to slam it into reverse at a good rate of speed, there are time you have to use reverse to control the boat. Just be smart about it and at idle speeds if possible. JMHO
Thanks. That was my plan. Will practice some to see how it works out and of course try not to forget to use the reverse lock. LOL
The manual tilt lock on many OMC outboards is intended to hold in reverse at normal reversing speed. A lot of people are afraid to use it though, for fear that it won't tilt up if they hit an underwater obstruction. But they are designed to release in that event. Don't believe it? Clamp the motor on a boat on the trailer, lock it down, then hunker down behind the motor and give a hard yank on the lower unit. It will give a loud bang like you busted something, release and come up. Not to fear, the bang was merely the big spring as the lockdown released.
Great fun with an inboard. Roar up to slip. Throttle lever to idle. Shift lever to neutral. Coast a bit. Shift to reverse. Throttle up until the hull stops. Prop walks to port, so alternate fwd and reverse at idle until can reach the lines.
Sometimes startled by the high pitched screaming until I remember I'm alone in the boat.
you obviously dont understand the reverse lock mechanism that is on some drives and outboards.
my suggestion is to take a boaters safety course if you havent. then to get the hang of boating, boat on a big-open area and take it slow...... slow down long before you want to stop.
