Reverse issues
racerman16
I have a 84 chapparal with a merc i/o 120. I put it in forward no problem goes and drives. Put it in reverse and it sounds like stuff is shattered to pieces or just barely catching a spline or something but it wont move.... Is the transmission bad or is something not adjusted in the trans? The unit was "supposedly" rebuilt a few months before I bought it. Thanks.
Re: Reverse issues
Ayuh,... Sounds like the Lower shift cable is gettin' Bad...
You can try adjusting it, but most likely you'll fix it by Replacing it...
The factory manuals are available up in the Adults Only section at the top of this forum...
