I have a 1977 500/50, s/n 4805706. The hooks for reverse lock move maybe 1/2" when reverse is engaged from the controls, the hooks can be moved throughout their range of motion fairly freely by hand. The pushrod also seems to have a lot of play up and down. This did not work properly before I had the LU off yesterday to do a water pump so I don't think I did anything to affect its operation. I did not notice any damage to the reverse lock cam although I did not remove/reinstall for inspection :facepalm:
My water pump now pees like a champ so it's not all bad.
My question is, is there any other adjustment for this aside of the the nut on the pushrod right below the hook assembly? Any other parts to look at before I pull the LU again to check/replace the cam?
BTW, I do have a factory manual on order, just trying to get this done for today's trip on the water.
Also, I have read on this site that there is a newer steel replacement for the reverse lock cam but I cannot seem to find a part #. Would this be the cam made for same model year as mine but after the higher serial number break?
