gavin dunne
- Joined
- Jul 17, 2005
- 23
Hi. I have a 1981 Mariner 30E #689L 405415. The problem is that the automatic reverse lock doesn't operate on engaging reverse or neutral. There is a lever on the transom bracket which can be flipped to engage/disengage reverse lock but this isn't interlocked with the actual shift mechanism. Should the two be interlocked or is the reverse lock purely manual on this model. As I have remote control I don't want to have to keep going back to the stern when ever I change gear. I had the lower unit off earlier this year and now am worried that I didn't assembe the shift linkage correctly. However there wasn't any cam evident on the shift rod when I dropped the LU. Schematics at dougrussel.com don't show cam either, as far as I can see. The seloc manual I have doesn't mention a cam or the reverse lock anywhere.
