I am use to running various outboards engines on a recreational basis,
but wonder which engine models/types (expect to run twins)- have
the best reverse mode.
The commercial operation - I'll be running is pulling heavy mooring
lines from a commercial tanker vessel or other type (rope and/or wire
lines) mainly in reverse from the vessel hand-off to a mooring dolphin.
The engine strength in reverse is as important, if not more than in
the forward mode.
I realize that most engines are not designed to turn high RPMs in reverse,
but are some better suited than others ?
The boat is a 23' Aluminum Hull (workboat) - Mon Ark (Sea Ark) type -if
you know the model - no engines currently, it previously ran twin 115 HP Yamahas, but was not used in this type operation - reverse pulling power.
Rgds, Dennis
the forward mode.
Rgds, Dennis
