projo198
- Joined
- Jul 7, 2012
- 317
1988 Bayliner Capri w/ 2.3L Ford.
This is my first time winterizing, so please let me know if I am on track. The boat will be stored outside in eastern Kansas, we usually have mild winters but it'll still go below freezing a few times.
This is pretty much all from the original owners manual, but I did have a few questions about products because often it calls for OMC-specific lubricants.
1) Add fuel stabilizer. It doesn't specify how much, but I am guessing you add according to how much fuel is in the tank. I was planning on leaving it at about half a tank (around 11 gallons) and adding accordingly. Is there a particular type or brand I need to get, or will any gas stabilizer work?
2) Change motor oil. I'm still not sure on exactly what oil I need to use, but I am suspecting a marine grade SAE 30 4 cycle because the books says to not use oil with a varying viscosity. Is this correct? Also the oil pumps I see at Bass Pro are very expensive, can I just use a cheap auto parts store suction pump to drain the oil?
3) Fog motor. Pretty self explanatory, but any particular type or brand of fogging oil?
4) Drain the cooling system. I know there is a petcock on the exhaust manifold. The book mentions a cylinder block petcock which I have never seen. I am also going to detach the big hose at the water pump, and have to find another to the thermostat?
5) Drain pivot housing. 2 drain plugs; one port and 2 starboard. Store with trim down. That's it, right?
One thing I am skipping is changing the lower unit oil. I am doing this because I did this just a few weeks ago and have only had the boat out twice since.
So am I missing anything, or can anyone fill me in on the questions?
Thanks guys!
Thanks guys!
