Normally my engine runs faultlessly and, the last time I used it back in June was absolutely fine.
When I used it last weekend, the engine started fine as normal and, ran fine as normal, up to about 4,700RPM. It was happy sitting there steady, with no issues at all.
However, when I pushed it to WOT, it sat at 5250RPM as it normally would but, only for 3 seconds or so, then, it started stuttering. The revs were fluctuating between 4,800 and 5,250.
When returning below WOT, it was fine again, happy holding the revs constant and, running as smooth as it normally does.
Any ideas what's caused this all of a sudden?
My initial thoughts are a quick tune of the idle mixture screws on the carbs.
My next port of call is the timing, which may be ever so slightly off.
Any other ideas to help me pinpoint?
