Re: RH Cam
J cizzo
how many RH motors have you actually rebuilt or worked on ?
years ago the old hotrod gear drive setup allowed the cam to rotate RH while the crank still rotated left, then came the pete jackson style gear drive with an idler and later a floating idler that required no machine work.
yes on the marine RH motors we actually have both cam AND crank rotating RH, the oil pump and distributer drive gear,in some cases the complete distributer, was different as were the rear main seals and the starter.
wanna see someone cuss, let them use a LH main seal on a RH mtor
I never did it but I have seen it done
but like I said, the bean counters have pretty much made everything LH now. it simply cost to much for such a limited market to manufacture all the RH stuff when most modern cluthes can be made bi-directional, some have to have the pump flipped, others its as simple as changing from push for fwd to pull at the bellcrank.
last RH cam I needed was for a late seventies 440 chysler, crane built it, but it tok nine weeks, I had to send in the old cam and it cost my customer almost 800 for a cam.
and that was about 1992.
