Rick !!!!! 1987 50 hp johnson what are the best plugs
fpctim
i would like to know what the best spark plugs are for my motor,i mean top of the line ?
Trent
Re: Rick !!!!! 1987 50 hp johnson what are the best plugs
Sparkplugs do one job. Change them regular. <br /><br />NGK= BZ7HS-10 gap .030<br /><br />Dont waist your money on splitfire and other gimmiks.
snapperbait
OMC recomends Champion QL77JC4 or L77JC4 plugs, gapped at 0.040 for sustained low speed operation..<br /><br />For sustained high speed use, Champion QL78V or L78V non adjustable gap plugs..
fpctim
i do not wish to buy split fire ,what im after is what the oem plugs are or do they have double plainums or what? i do not agree that plugs are plugs and do the sameas other plugs,some after market plugs will work in motors but may not have the same heat from the spark and may not fire like oem .
snapperbait
The Champions I recomended above, are the plugs recomended by OMC/Johnson/Evinrude as oem. replacements...
rickdb1boat
Tim<br /><br />Champion QL77JC4 are the best for your motor. A platinum plug will not nessesarily provide better spark, but it may go farther between changes. I don't know of any cross from a QL77JC4 to a platinum plug. I have no problem with the standard plugs lasting a whole season.
fpctim
thanks rick and all the motor is runnig great it was all do to a bad plug wire ,i just want to make sure i have the right plugs in my motor
