Re: rigging of a new boat?
It depends on how "rigged" rigged is. If it was pre wired, instruments set and wired and the box and cables were pre run:
Engine de-crating, hoisting, mounting, attachment of everything at the engine, battery, PDI check list, actual test run, running down why it runs like crap, fixing why it runs like crap, bitching at boat manufacturer because they had a wire hooked up improperly, another test run, running it again for you so that you can actually see that it runs, explaining to you what a marvel of mechanical engineering you have bought, hooking it up to your car and watching you leave, wondering how long it will be before you come back in because it runs like crap again....About 8 hours for a kid with a little aptitude to do everything twice.
But, crap happens all the time on engines. Little things that throw a delay here and there. Most service departments will tell you 24-48 hours from when they have everything available. That way if they need some $1.00 part to finish it doesn't make them look stupid. Five day's means they either had something better to do, had a major problem with some aspect of it or decided they don't like you
