Re: right height for motor
Hi Rockytop,<br /><br />You don't say what motor you're running, but there is usually some 6 to 9 inches between the AV plate and the propshaft. If that's true in your case, then your AV plate will be a little high.<br /><br />Theory says that the AV plate needs to be level with or a little above the hull bottom at centreline. I've been on boats that have performed well outside this range, but it's a good starting point.<br /><br />Does your prop ventilate easily now - say in turns? If so, try dropping the motor down a little, and experiment.
