Right Prop? Bitten by a rock.
Rodb
Had an arguement with a rock avoiding kids in canoes, very low speed impact but prop is bent. Straightened as best I can but not good in long run.
No idents on prop at all. Engine is Force 50 on Bayliner Capri bowrider. Any suggestions to get me up and running again. Not looking to ski just two adults average weight.
steelespike
Re: Right Prop? Bitten by a rock.
Take it to as prop shop thay can repair easily at a reasonable price.They may be able to help with a replacement as well.There are also props right here on iboats.If you go to the prop forum give them the boat/motor specifics prop numbers,rpm if possible and how you use your boat they can make some suggestions.
roscoe
The prop should have some sort of markings, inside? outside? back side? somewhere.
JB
Did you consider the Prop Forum?
