Re: RIGHT PROP
Brad, with all due respect, don't even try to compare an auto 4-stroke to a Marine 2-stroke.<br />#1., I have used every type of tach in production on my 200, including a direct-drive intended for irrigation engines...I know EXACTLY what my engine turns. And, when playing with exhaust gas temps and cylinder head temps, ya learn real quick what the truth is.<br />#2., Dhadley has to give back all of the countless Trophies, plauqes and awards he's received over many, many years of Boat racing, and Marine engine and parts developement, because apparently, he never tested anything to prove this, so he really couldn't have won all of these items because he didn't stick to the factory specs, and still doesn't, because we've researched and tested, then tested, and then tested some, and then tested more and found out maybe this way works a bit better.<br />#3., If you choose to run ANY outboard at a max RPM of LESS than the TOP of the range, I can tell you right now, my engine will outlast yours and have twice the life.<br />The older the engine is, the more important it is to keep the RPM set-up to achieve at and better yet,slightly above Max recommended.<br />The info posted by Dhadley and myself on this issue is not a "Thought", it is a proven "Fact".<br />By the way, Brad, Dhadley has some V4's he turns close to 9000RPM, and the funny thing is they stay together....while blowing past V6's in the process....NO, don't go set up for 9K...a stock engine(2-stroke carbed) runs out of air before it can over-rev anyway.
