Rim seems to be bent or axel maybe??
ahendri
i recently bought a new boat and it seems like one of the rims is out of alignment maybe the hub is bent because it is not centered under the wheel well... is there a proper way of fixing this or is beating the crap out of it the best way... i thought about using a come along and slowly pulling it back into position but i don't know where would be a good place to anchor from
can-amsledder
Re: Rim seems to be bent or axel maybe??
What??? No! Don?t get the come along out yet!!! Get out the measuring tape! Maybe it?s just the fender that?s out of place.
ahendri
it seems like the tire is closer to the frame on the back side of the tire than the front...
can-amsledder
Your going to have to get out the tape measure. With someone?s help measure from the coupler to the axel by the leaf spring on both sides. You should end up with the same number or at least very close.
How does it tow? Does it look like it dog tails?
ahendri
well its an older trailer and when we were bringing it home we actually lost a tire but it seemed to wobble a little bit could be because the boat is not centered on the trailer right i noticed but im no expert...
