Ring end gap clearance
Mettaree
'96 V6 2.5L 200hp. Have read that standard acceptable end gap is .005" per inch of bore. My bore is 3.500" so acceptable should be .0175" end gap. OK. What should be considered minimum gap and maximum gap for 3.500 bore? Of course, end gap being measured w/ring in bore and square - top, middle and bottom. <br />Any help greatly appreciated.<br /><br /> :)
Mettaree
Re: Ring end gap clearance
No overhaulers/rebuilders out there have any figures that I can use.<br />Thanks........<br /><br /> :)
Hooty
.007" min.<br /><br />c/6<br />Hooty
Mettaree
Hooty :<br />Thank you so very much - was holding me up.<br /><br /> :)
Dhadley
We used to use .007 to .017" as standard. anymore .007 is considered a tad on the tight side with todays fuel, but acceptable. <br /><br />With todays ring material and combustion temps we are more concerned about the rings being too close and touching. Some rings have a clearance of .030 or more. It depends on the ring design and ring material. <br /><br />Its always a good idea to check the ring gap as a cross check to bore size (to avouid a .020 labled bore when its actually a .030 -- it happens) and to make sure the right rings are in the package (that happens too). But its pretty rare, if ever, to have to "size" a ring these days.<br /><br />Good luck!
Mettaree
Dhadley: Many thanks.<br /><br /> :)
Dhadley
Hope that helps.<br /><br />Whose rings are you using?
Mettaree
The ones that came with Wiseco Pistons I ordered<br />(STD)<br /><br /> :)
Dhadley
They should be good to go as is. I still put each one in just for the other reasons I mentioned. I dont really measure them but you'll see right away if something doesnt look right.<br /><br />Let us know how you make out. Good luck!
Mettaree
Dhadley: Slipped ring in both holes ( 4 & 6 ) top, middle, and bottom avg. abt 20-22 thou. Thanks much for your info.<br />Later<br /><br /> :)
