I am boring my 3 cylinder Johnson.
It is around a '89, but has been worked on before so I am not sure what to believe.
It cracked the # 3 piston after maybe 20 hours of use on a "rebuild", (Not me) possibly incorrectly as it appears to me that a ring turned on the piston and caught a port.
Seloc lists a ring gap of .07-.17 for 88 and prior, and a ring gap of .19-.30 for 89 and up.
How do you tell which it is?
Is it in the piston design?
Mine appear to be the newer pistons without the extra skirting I have seen in the book.
Correct?
I have new GLM .30" + pistons for it now.
As well piston clearance is not listed, what should it be?
Do I trust that the GLM pistons are .30" larger than oem and bore to 3.187 + .030"?
Thanks.
Correct?
Thanks.
